"Firmware Watcher" question .... | SatelliteGuys.US
outerub
100
Michigan.
Why are the HR22 & HR23 not on the list ? I saw that the HR21 was on the list for 34C and was able to grab it.
Just curious.
Regards,
UB. :)
Because they use the same firmware versions as the HR21's so no need to duplicate listing them.
Is there a reason why if you post a link to the firmware watcher, that the post is discarded?
http://www dot redh dot com/dtv/index.php?r=HR
Thats the only way I can make it work.
http://www.bob.com/dtv/index.php?r=HR
Don't know, you might want to post that question in the site's operation forum to see if you'll get an answer there.
New Feature Suggestion.
DTV Dish Type
