Fixed 90cm FortecStar pointed at 93w + 123w.. suggestions. | SatelliteGuys.US
pro96
You Member, Member ?
6,464
15
OC
I'm trying to determine if I can get both 93w + 123w using the same 90cm Fortec Star dish using 2 LNB's and a home made bracket.
My old folks have it fixed at 93w right now for the Azteca channels, and now they want to add the spanish ones at 123w w/o having a dish farm or motor.
Although I did suggest for the motor, they don't want to deal with moving back and forth and want instant channel tuning. LOL
So I was thinking in pointing the dish at 103w and make a home made bracket to mount 2 Linear LNBs and adjust them at 93 and 123.
If anyone here has done something like this or similar, if you can post your settings and results. I would really appreciate that.
All suggestions are welcomed, and if you have pictures of something I am trying to do then please post them here.
Thank you guys
BTW: They live here in L.A
Thank you guys
Since neither is going to be in the center , sweet spot of the dish , it may take a larger than usual dish ?
Here is what I would try first .
Connect the coax to the second LNBF and by hand , move the LNBF around ( with a signal meter in-line so that you can read it , hunt for 123 , leaving the dish aimed where it is .
May or may not work , but may yeald valuable information .
Remember , the bounce from the west sat will be on the east side of the dish . And vice versa .
Wyr
God bless
I will try as soon as the temps drop below 90.. :rolleyes:
over 100f is just too HOT in the San Fernando Valley to mess with the 90cm.
The transponders on G10 offer a notoriously weak signal (they have improved a little with the recent changes on 121). So you may have to try focusing on 123 and using a bracket to aim for 93, assuming 93 offers a good strong signal on the Aztecas tp.
My 90cm does a good job with G10 but I do not think it would do very well trying to pick it up with an offset to the side. My P*84 just barely brings in one of the Equity tp.s
Another one dish possibility, albeit expensive, would be a Torodial 90. I doubt the T55 would work.
Good luck.
Good luck.
Yeah I thought about that too.. re: Lo TP power at 123w.
This is gonna be fun for me tho, so I will post some pics as soon as am done.
Mickey mouse and all, it will be accomplished with the home made bracket :)
Legacy analog ird w/ qph-031 switching??
Pansat 3500SD, Apparently Shorted Out
