FMC (Channel 387) Moving to Streaming Only | SatelliteGuys.US
That link doesn’t take you to any information about fmc.
What does it say at the link for you? When I go to that link it says:
Important Update for FMC Channel 387 on DISH​
Effective February 12, 2025
We're excited to announce that FMC Channel 387 is upgrading to High Definition for an enhanced viewing experience starting February 12, 2025.
To continue enjoying this channel, make sure you have a DISH Hopper receiver connected to the internet. Most customers will not need to take any additional actions to continue viewing this channel.
To verify if any action is required to continue viewing this channel:
Step 1​
Grab your DISH remote and press the Guide button.
Step 2​
Try tuning to DISH Channel 198 (DISH scapes). You can type the channel number directly on your remote or scroll up or down the Guide to find it.
Step 3​
  • If you can see the DISH scapes content on Ch. 198, you're good to go! No additional actions needed.
  • If you see a "Connect to View" message on Ch. 198, don't worry! You just need to connect your DISH Hopper receiver to the internet. We have easy-to-follow instructions for you.
  • If you are unable to see Ch. 198 in your guide, you most likely will need to upgrade your system to a Hopper receiver. Contact us at 800-333-3474 and speak with an agent on what special upgrade offers are available.
I think they are working on streaming channel recording. Maybe it will even let you skip forward and backward as well…
Comcast has been doing it with their Roku app for years...I don't know how they are doing it...its all cloud based..not on a hard drive
Reactions: charlesrshell
There goes channel recording.
From a technical viewpoint, if YouTube TV can do so, no reason why Dish cannot.
But there could be licensing issues that we do not know about.
another channel lost, yet continuing price increases
dish customers again take a hit
The channel is not lost, simply moving to a streaming channel and making it HD at the same time. Of course if you don't have an internet compatible receiver, yes, you lose the channel. It's time to upgrade that receiver.
