folders | SatelliteGuys.US
folders
mobimop
37
Southwest
Is their a maximum number of folders you can have on the 922? Also I seem to have lost the "create folder" option today when I added a new timer. How can I create more folders?
How many?
not sure, you would need to search fot the post where the user stated how many he was able to create before the option went away. If I remember correctly it it a small number.
I am pretty sure if you just let it make its own folders by title it has no limit to those.
I would love that same thing my Tivo HD did however I don't see that option where is it? If you don't define a folder when setting up the timer for a show it just throws everything into the "no folder" folder which has become a mess.
it should be on one of the dropdown menus on the DVR screen and I believe you can also set it as a default on the series recording default screen.
I am guessing these kocations since I am not by my 922 & slinging does not show all of the menus you can get on TV1.
They are in folders by title, that is the default. After pressing the DVR button check the second drop down menu and make sure folders by title is selected.
Adding 118.7
Muffin fan & VIP222K
