For Suggestion to which one to subscription | SatelliteGuys.US
Vipul
7
India
Hi guys. I have bought openbox X6 and 6 feet satellite dish. I want to watch live feed of cricket without any delay. So please suggest me how can I see this.
Well first off :welcome to Satelliteguys
I see you're located in India, so Cricket matches should be found on the satellites over Europe and the Mideast, as it's not that popular in the U.S. I can certainly say I haven't seen a match recently, on any CONUS satellite, anyway.
You'll probably get better advice on a European, or Mid-east forum, satguys is pretty much N America. We have a only a few members from across the pond, and none east of Belgium that I know of.
Happy Cricket hunting via satellite.
Vipul check out satellites.co.uk they are a European based fta forum they would be able to help you out more.
Hi guys.
Please tell me on which satellite I can watch this channel?
3781/7125/H
On which satellite this is available?
Sent from my Nexus 6 using Tapatalk
Not enough information. A frequency (C band 3781) polarity(H) and SR (7125) may be found on any satellite that has C band transponders.
If you have a channel name, sometimes this works , do a google search like this: NAME site:lyngsat.com
Found a reference to 3781/7125/H being on Intelsat-IS-20 . 3781 is not on IS-20 anymore. But it looks like this might be the satellite you are looking for. There is a cricket channel on Intelsat-IS-20 and the satellite signal footprint for India is good. You'd need the correct Conax card to receive the cricket feed on 3712. There are quite a few free channels on IS-20 maybe cricket is available on some of the free channels????
http://www.lyngsat.com/Intelsat-20.html
http://www.satcomresources.com/tools/Intelsat-IS-20
$535 for a 1x2 switch? Really?
STAB HH90 - OK to use the mount included with my 90cm dish?
