GEOSATpro - For the folks who got their MicroHD | SatelliteGuys.US
GEOSATpro For the folks who got their MicroHD
Mr Tony
3,357
14,732
Mankato, MN
When you get your MicroHD make sure you have the newest software before starting. Check the system info screen and if it has software before 1/1 I suggest updating it to the 2/27 software (or if SatelliteAV has newer available)
It will make it easier to troubleshoot if you run across any bugs
link for it is here:2/27/2013 software
Thanks!
oh one additional note with the software
After you do an update its best to do a factory reset after it updates. I've run into a few bugs after a software update and after it reboots then do a factory reset again. That fixes it :)
