Force a guide update | SatelliteGuys.US
Leafs99
30
Seattle
Is there any way to force a full guide refresh for HR24 DVR's? Other than the obvious one of unplugging it :)
You can do a proper recvr reset, that will reset everything, much like the proper way to shut off your computer.
Menu/Settings/ReSet/ReStart Recvr/ dash
If you are trying to get the new HD GUI, then you can't. It does not start rollout to regular customers until 11/8, and then you will only get it when your receiver is designated for a download. Could be weeks before everyone gets it.
You have to reboot the HR twice within a half hour to flush the guide data and have new data downloaded. Works well for sluggish HRs of all models.
Rich
Signal #s Decreased on the 103 ca/cb
Shutdown DVR
