Force guide reload | SatelliteGuys.US
Force guide reload
n0qcu
5,153
2,001
Earth
How can you force a guide reload on the 922. NONE of the methods for other receivers works.
I tried:
999 right arrow
check switch
and
reboot
Nothing worked.
Also I at this point haven't figured out how to lock out unwanted channels. (like all those shopping & info channels below channel 100)
You have to undo the two antenna in. Uplug the system wait 30 seconds. Then repug the system. After you get to the aquiring sattellite signal screen rehook the two anttennas and it will force a redownload of the guide.
I figured this one out.
It required the use of the new "jump" button
211 USB Hub
CSN Philly -- When???
