Right now and for awhile, it's showing old UI, Not the new one
So there is a confirmed routine, I know earlier it wasn't working.Red button reset. When white light comes on hold down add client button until white light is flashing.
Download is in progress when white light is flashing.
After red button reset when white light comes on hold down add client button while white light is flashing and what is the hold down add client button? Thanks for help appreciate the helpRed button reset. When white light comes on hold down add client button until white light is flashing.
I didn't hold the button down, just a poke. I will give your method a tryRed button reset. When white light comes on hold down add client button until white light is flashing.
Well I tried holding the button down until solid white, did not work. now what?I didn't hold the button down, just a poke. I will give your method a try
SSTV
After reset, the top light turns white and you hit and hold the button until the white light starts blinking then release the button. I think we are both saying the same thing.WHILE solid white. Once it turns white THEN hold button down UNTIL it starts blinking.
When have you been trying ?After reset, the top light turns white and you hit and hold the button until the white light starts blinking then release the button. I think we are both saying the same thing.
SSTV
when the new software is shown active at REDHWhen have you been trying ?
Limited time offer
