Fortec newbie | SatelliteGuys.US
Fortec newbie
draggon_9
I'm still setting this up. I have the M-2 package from Sadoun only with the 100cm dish upgrade. I have a few sats. programed but I can't get it to GO TO or MOVE more than a few degrees at a time using USALS or DiSEqC. My dish is only 50' away. I don't think the cable is bad but I'm going to try it closer to the dish tomorrow. I'll take any other suggestions if this doesn't work. Thanks.
50 feet should be no trouble at all, some members here have 200 feet or more.
You might check the fittings on the cable, also be sure to use RG-6 cable, not RG-59.
Looking to get an FTA system, but have a few questions
Wild Feeds on SBS6 72.0W & ONN Question
