Well guys the bad luck reign on the getting new equipment seems to still Plague The B-Man! I just ordered a motorized system off of Sadoun and it came with a bad remote right out of the box! I ordered a Mercury II but wanted to get the new Dynamic and Sadoun made that happen! Got it here the other day and took it out of the box to set it up for a friend and the remote does not work at all! This is not Sadoun's fault, just a manufacture problem or ruff shipping buy UPS. I did find a small crack in the remote case but there is no box damage so your guess is as good as mine! So disappointment follows since I really wanted to play with this new Fortec! I should have just got the Mercury II since they are discontinuing those; the one I got is still a very solid box! I tried the Mercury II – Classic NA – Fortec Ultra remotes on the Dynamic but no avail, guess it has to be its own remote! So, I wrote Sadoun, and they are going to make it right! That's what Gold Sponsors Do man, treat you right! I can't do much of anything to the box though without a working remote. The scan feature needs the GREEN button or POWER SCAN button to work to even get anything channel wise into the box's channel memory so all I see is the OSD! I can't even set the time without a remote. So, my friend has my old Coolsat 6000 until we get this Dynamic working for her! It seems every STB I get has something wrong or the box just does not work. It's a FTA curse!
You all can remember the 3ABN dish mishap; the old metric bolt broke and took down my dish in 1 day of setting it up. The famous Coolsat 6000 problem where I ordered 2 brand new ones from a FL dealer and one did not work. And my new CNX Mini had to go back and get replaced because of the receiver not sending USALS commands to the dish, now this new Fortec Dynamic problem. If there is a bad product out there that is manufactured wrong it seems I have got it sent here this year!
Joking aside,
Change of gears..........
Fortec Star 80 CM dish question.......
Does anyone know if the scale on the new Fortec Star 80 CM dishes is fixed? I know that we all had problems with the scale not right in the past and I was wondering if that problem was fixed on the new run models since. I put one up Saturday for a friend and I have the middle of the arc but nothing past 87.0W & 103.0W. I have everything at with great quality from 87-103 West. I suspect the scale is still wrong and I will look where my motor and dish scales are at and adjust them the same in the afternoon today. The new system just went a couple houses down from me so the scale and settings on the dish should be the same. I was just curious to see if they are still stamping these 80CM's with the scale off still.
Joking aside,
