Has anyone had much luck cloning the software & channels STB to STB on a Fortec Star Dynamic? The book says connect a RS-32 cable to it, in which I done but it still says "turn on the slave IRD" on screen.
I know these boxes RS-32 ports uses NULL MODEM cables but is this feature done by a standard cable instead? I got a new Dynamic yesterday from Sadoun and it is getting installed for a friend tomorrow and I would love to clone the satellite list over to it from my Dynamic (Fresh Blind Scans on all Satellites from last night to today) to keep from having to do it at the new install location. Thanks for any input!
Instructions from the manual:
Firmware Download
You can transfer the firmware of your receiver to another receiver.
Please connect a slave receiver with a RS-32 Cable
Database Download
You can transfer the Database of your receiver to another receiver. Please connect a slave receiver with a RS-32 Cable
Page 18 under Operation
It says nothing about a Null Cable which I am using,,, and does not work! NADA!!
B~Man
Firmware Download
Database Download
B~Man
