Fortec Ultra and Twinhan USB Coexisting | SatelliteGuys.US
caddata
333
Jacksonville, FL
Do any of you guys swap between Fortec Ultra and Twinhan USB receivers using the same dish and LNBF's?
Do you rotate the dish with just one receiver and swap the coax or use a switch? If so, do you return the dish to the "home position" before swapping receivers or will the dish account for the change of receivers by using it's own USALS rotation calculations?
Any other complications that I haven't thought of?
Thanks,
Harold
some people just slave the card (or a second receiver) to the main. The main unit controls everything and the slave would only get the same polarity as what the main one is on.
So if both are on, the fortec would get both polarity but the card gets the same as what the fortec is on. Turn the Fortec off, and the card would have both polarities :)
Question about blind scanning.....
Difference between 90cm and 1m
