Fox DN east feed (SD): what transponder? | SatelliteGuys.US
chuckles2
31
I have 2 sd tivos fed by separate dishes, one is having no problem with fox, the other is, the technical term I believe, is crap.
I'm trying to see if I have a dish alignment problem small enough to be not readily apparent- the two dishes seem to be aimed the same, i.e., similar reading on various transponders.
Anyone having other ideas:( please share..
and gosh its hard to find an up to date transponder list.
Thanks for the help -
now I'm really stumped, both receivers show a 96/97 strength for TP30, yet one gets breakup (live and recording) on Fox, the other does not. Other DN record fine.
I've been messing with DTV since the initial trials in MS and LA but this old boy be lost.
sigh...iceberg you know that was what I didn't want to even think - could well be, these are old tivos, still odd just one channel. Oh well i'll just live with it.
I have both E and W Distant networks, and as I understand can't have them if I go HD, and the boss says I won't have ////// I mean she said we needed to keep both feeds.
If this keeps up guess I'll to op for a DTV non-tivo replacement (SD).
HR34 showing "upcoming shows" in the past???
Best buy rebate & refer a friend together?
