Fox HD in Houston | SatelliteGuys.US
Fox HD in Houston
dcwebman
274
Spring, TX
Not to take away from the new channel chatter, but I had a question on my local FOX HD dish feed from Houston. I'm not sure if it's the channel itself or something else but I saw it last week in Prison Break and this week too. Sometimes, it's perfect HD quality and then the next it's like I'm watching a poor version of SD. I saw the same thing in my OTA HD version so I'm leaning it toward being a channel problem, but I'm wondering if it's just me or not?
If you're seeing the same thing OTA it's a problem with the channel/network. I have the same problem with my locals here, which I get OTA and (all but one) via D*. I put in the antenna thinking my PQ would improve, but it didn't - at least not much. The MPEG4 feeds from D* for locals are pretty good...
The funny thing is that it used to work fine. But I've had to replace receivers a couple times in the past few months so that may be it too. I now have 2 HR20-700's and for some reason, the OTA signal on my original is 100% on most channels but the replacement one I just got only hits 77%. I'm going to try switching cables this weekend but I'm guessing it may be something bad with the OTA tuner in that one.
Could be a difference in the lines as well - is there a splitter? Is one cable run longer than the other? Using different kinds of cable?
I live in houston also, not only does the picture get sketchy, but the sound also sucks terrilby on Fox houston
Thanks for the confirmation that Fox is having problems. I also am seeing major problems with dropouts on KHOU (CBS) too, both on the dish and OTA. I discovered last night what I think the difference is. If they are broadcasting a non-HD show like Survivor that's when it happens. I didn't see any problems during CSI which was HD.
There is a high quality splitter and the cable run coming from that to each receiver is about 5 feet. Like I said, the previous receivers I had on that line were fine. It's just this latest replacement. I'll try switching cables this weekend.
Directv HD Thoughts
New HD with The Family Pac with the Old HD Pac Question?
