From Dish Hopper w/Sling to DirecTV Genie (HR44) | SatelliteGuys.US
lparsons21
9,925
8,073
Herrin, IL 62948
For those contemplating making a switch to DirecTV from Dish, here's a few things that you'll notice.
1. The HD PQ on Direct is better, but the difference is slight to most eyes and certainly to mine. Noticeable, but hardly earth shatteringly different.
2. With the HR44, D*'s SD now is watcheable. Wasn't on previous HRxx models I have had at different times. It is very channel specific, with some being very good and some not so good at all. That channel specificity is there with Dish too, but Dish't SD is better overall by a fair amount.
3. The user interface. For all the blathering that went on in the Direct sections of the forum, the current user interface is nearly identical to the previous non-graphic one, certainly in the layout and how you do things. The GUI reminds me of 80's era MS-DOS 'graphics'. Functional, but not very graphic at all.
Well, there is one place I suppose the GUI got a boost, and that is in the ability to stuff lots of ads in the channel guide. IMO, not much of a benefit to the user, but I suppose it makes the marketing guys at D* happy, although they don't make me very happy. :)
One of the biggies IMO, is that the guide width on D* is only 1.5 hours vice the 3 hours on E*. I've never understood the reasoning behind not changing that when they went to a HD GUI. Seems a horrible waste of space. And because of that, the guide screen and most other screens are really in your face on big screens. It would take some really horrible vision to not be able to read that screen from very far away.
Dish definitely did their homework on their Hopper UI.
That said, the D* UI is very functional and if you had never had the Hopper, would remind you of all that older equipment we've all had over the years.
4. Search - Both D* and E* have excellent search abilities these days. D*'s is very flexible, and if you take the time to learn the boolean searches, some amazing series links can be setup. It is a little more complicated to use, but can be worth the effort for some. My only beef with D*'s search is that it is 'fiddly' to get to it. No one button to search with D*.
But overall, I'd have to say that right now the power and flexibility of search is pretty equal, with the difference being mostly in how you get to it and interact with it.
5. Premium Programming -
While Dish has a wider selection of movie channels because of the Epix channels, Direct has more movie channels in HD. It is just that simple. While it is nice to have Epix, Epix is probably the worst premium movie channel when it comes to incessant repeats IMO. I had Epix as part of my Dish subscription for most of the time, but finally cancelled it out as it seemed they just didn't have enough new movies to make it worthwhile.
6. Sports - we always say that if you want lots of sports, D* is the way to go, especially if you want them in HD. It isn't that Dish is horrible for sports fans, it is just that D* is much better for them.
Even for lesser sports like Boxing. I can and do get many more boxing shows on Direct that just weren't available at all on Dish. The downside to series links for boxing and UFC stuff is that the guide data is very poor so even if you select only 'new' showings, odds are you will get a slew of very much not 'new' events.
7. Speed - It used to be that D*'s equipment was doggedly slow compared to anything from Dish. And that is still true up through the HR34. But the HR44 Genie is faster than the Hoppers by a little bit for virtually all interactions. Never thought I'd be able to say that about D* equipment.
8. VOD - Direct has an edge here with more of it, or at least it seems that way. And getting to VOD on the Genie is easier. You can go through the Menu system to get to VOD, but you can also get to a channels VOD directly from the guide. You just left arrow over to the channel number and push 'select' if the channel number has a "+" on it. Also you can get a listing of the next couple weeks of shows by selecting the channel number and pushing the 'Info' button. Both very handy.
9 Billing - If you choose credit card autopay, D* will pull the money before you can even view the bill. Pure idiocy on D*'s part imo, but that's the way they do it.
Don't forget that the Genie can run 3 clients simultaneously for 4 separate channels in 4 separate rooms whereas the Hopper can only run 2 joeys. This is where Dish fouled up with the hopper............
SIG
That is incorrect. The Hopper can support 3 Joeys though just like with the Genie, who would want to? I know I wouldn't even consider it in either case.
The Hopper could provide 3 unique channels to any combo of the Hopper/Joey in that situation, with the last one either sharing a channel or watching a recording.
The scenario for a single Hopper or a single Genie with more than a couple of clients is just not a good solution imo.
New Dish?
WJRT in Flint will no longer be on DirectTv (Agreement Reached)
