Frost Line | SatelliteGuys.US
Frost Line
Hey,
I've attached a Frost Line Map, hope it helps!
kresston
That map seems a little extreme. In Minnesota the code is 48 inches for footings. Usually in winter the frost is 2-3 feet deep. Call the city and talk to someone in the Engineering dept. they should be able to give you an idea of how deep the frost goes in your area.:)
Where can I get a Pole to mount a dish?
Any new HD channels on the horizon??
