FS/FT Glorystar Sat Tv System | SatelliteGuys.US
stogie5150
Crazed Cajun Rebel
3,839
85
Slidell,LA
I bought a Glorystar system and never use it. it includes 90cm dish,mercury II receiver, single LNB holder,dual LNB holder, BOTH with LNB's, 3 total, disecq switch, cables, lag screws, everything you need.
I'll take 175.00 plus whatever shipping we can arrange, or I'll swap it for whatever you have in that price range. FTA stuff, Home audio stuff, WHATEVER. Give it a try. This is in the way and it needs to GO.
before i order my upgrade kit, sure you don't have an extra dual lnb holder with dual lnb's that i could use?
Nope, I am selling it all as a kit. If someone is interested in Glorystar they're going to want the dual LNB setup. For exactly the same reason you do. :D
Still Available...c'mon fellas, no one needs a FTA system? I'll trade most anything for it if you don't have the cash, really. :D
Just to give y'all some ideas....I could use SATA Hard drives, DVD recorders, HD-DVD players, A/V receivers, old series 1 TIVOS that can be used without a subscription, C-band stuff, I am not in much need of any computer hardware other than the drives, nor networking stuff ....but otherwise anything of roughly equal value or nearly with shipping. I figure shipping it should cost at least 30.00 so figure that in...but really...I am flexible, I'll be glad to help a brother out if at all possible. :up
stogie, my friend, last time i inquired about this you were selling locally. i would have gladly taken it off your hands over a month ago.....sorry. meanwhile, my upgrade kit is enroute......now, if the installer will only answer his email!!
You bought a 3abn dish and a coolsat 5000, no? IIRC we talked about it and you came out cheaper....:)
yes and yes...but you know i would have gladly bought yours after my health crisis was over. but thanks for the tip about the dish. its still in the box, leaning against the wall waiting for the lnb upgrade kit!!
seriously, hope you find a new home for this soon! :)
Okay, thanks!
