fta and bud | SatelliteGuys.US
fta and bud
mapa
12
new questions (1) my question really was can you use a small dish lnbf on a 8.5 ft. dish and if so is there any adapter for this purpose? (2) does anyone have imformation on a geosatpro gsl1 c/ku lnbf? (3) i have only one feed from my dish to my home = can you comdine the c band signal with the ku at the dish and then split again at the receiver with out to much signal loss. thanks again for all imformation.
Can I add a question to this?
I have a BUD with C and KU lnbs. The KU is just for 4dtv right now.
The FTA guys speak of Circular AND Linear LNBF's. Does this mean to access FTA Ku I'd need (gulp) 3 ku lnbs on my feedhorn?
no
The only LNB that needs circular are the DBS slots (Dish & Expressvu). You can use a linear LNB for the other 20+ KU satellites.
Only 2 LNB's are needed (unless you really wanted to get the audio on Dish or ExpressVu)
What Berg said!
Iceberg said:
no
I have a 4dtv on BUD with co rotor II, Cband and .6 db ku band LNB's...get all the FTA I want just usung the KU normal LNB!
Luck
jeff
Yes you can and I have seen adapters but you can most likely make your own.
You can use 1 wire you would need a switch at the lnb. Most FTA receivers support the switches but the old C band receivers and 4dtv do not.
Just put your FTA receiver inline first and loop to your cband receiver. Use your FTA receiver to do the LNB switching.
Polar mount for a 5' Unimesh?
Anyone Recommend An Off Set C-band Lnb?
