Fta channel list | SatelliteGuys.US
Fta channel list
1inabillion
1,480
Vu+Duo.2/4Tuner HD:Zone
My Coolsat works just fine. I just reloaded my FTA channel list after renaming some feeds and a couple of the other stations.
Billion here
Iceberg
How does this Fta channel list that you use work. any input is welcome
set up ect. thanks
After I've scanned all the KU satellites and get the channels logged in, I use Channelmaster. You upload the channels from the receiver to your computer using the loader that comes with the Coolsat.
Once uploaded, you can either open it in the Coolsat channel editor program or Channelmaster. You can move channels around, rename them, edit transponder lists, rename satellites (C-Banders LOVE this feature because you can rename G10 X0 or whatever its called as example) :)
When you're all done, save it and download into receiver. and the updated list will work. And unlike the hacker versions, the legal versions always download correctly :)
Ok i think i got it thanks if not i will post what i don`t know.:)
Fortec Lifetime Classic NA firmware
Help With Missing Channels
