fta coverage from carribean | SatelliteGuys.US
all4jo
398
12
Haiti and lexington ky
i have a 1.2 meter andrew dish that i wanted to know if i could use a motor on. also i wanted to know if you thought this size dish would work from here?because if it does
i also have been looking at a winegard 76 cm dish which is cheaper.
thanks
Most motors will work on dish up to 1.2m but of course there are some real heavy dish out there that will not work.
The SG2100 motor works on dish up to 1.2m and is PERFECT for the Winegard 30" dish.
http://www.dmsiusa.com/sg2100.htm
What satellites are you hoping to get with the dish from there? Have a look at lyngsat and check the footprint of the satellite/s you are after.
How to work Satellite meter?
