fta hd programming | SatelliteGuys.US
fta hd programming
Bulbman2
74
now that there are more hd receivers available- where can I find out how much hd programming is out there on fta
You can scan the charts over at Lyngsat, but you won't find much. PBS HD and Outdoor channel HD are on 24/7, and I think Movie Central is as well. The most things that you're going to find in HD aren't listed (feeds, etc.). Unforunately, I can't think of any HD capable receivers that have a blind scan to search out channels.
hd programming
why is there a lot of excitement over fta hd receivers if there is still limited programming, unless you are going to pay for hd thru a provider??
John
John
Besides the obvious nefarious purposes, we are thinking " If you build it , they will come". As HD receivers are available, so then maybe we'll see more programming. Even 1280x720 HD looks pretty GOOD!
I'm interested in a HD box so I can watch the 4:2:2 stuff (SD or HD).
Any HD content is just gravy. It seems that everything is going HD. The remote uplinks will likely be going HD too. Its just a matter of time!
Question on Hispasat channels
Twinhan 1027 and no dish
