rangers00 said:I know we are out of luck with AC3 audio. My question is, for these HD 4:2:0 feeds, can I receive them with my legacy 4:2:0 receivers? I have a DMT1050 and a Globecast.
voomvoom said:The QUALI-TV QS 1080IR High Definition Satellite Receiver. And it does 4:2:2 and QPSK. But, it's not cheap. I paid 700 for mine. It won't do a blind scan either. That's its worst flaw, there are other flaws. I'm not complaining. I use it every day. Now, I couldn't imagine not having it.
Al
voomvoom said:Also, the type of scans are:
NIT = the particular transponder frequency you have set.
Single TP = all frequency's on the particular transponder.
Single Sat = all frequency's on the particular satellite.
AUTO = all frequency's on the diseqc switch (up to 4) you have turned on for the particular satellites. You can scan 4 satellites at one time. Provided you have frequency's set to do a scan.
Al
yes123tim said:Could I reverse the original question for just a second to ask if HD feeds are backwards compatable with "standard" FTA receivers? What I mean is, as more and more feeds become HD will my receiver be able to decode less and less?
This is where I found mine:mk279 said:Thanks for the info .................... I've been doing internet searchs the last couple of days to get some pricing and shipping info. Every search result comes up from Europe. Shipping could be expensive.
Limited time offer
