fta reciver- cheaper than ariza 500 | SatelliteGuys.US
shahdad
30
I want to set up FTA, IA5 for a familty member but they want to spend the least amount of money
Ive got prices of dish and lnb but i was wondering what the cheapest FTA receiver would be
the cheapers i have found so far is the Ariza 500 receiver for $100cdn through local ariza wholesaler
as i understand it this model cannot be programmed like the pansat/ariza 700 and other fta receivers
I done care if i can program the reciver for "testing" i just want to get FTA
so what is the cheapest or next best alternative to the ariza 500 and where would i get it.
thanks
mikekohl said:
Try the Trimax T-100. A very basic, but very well performing receiver.
where can i buy this unit from? nothing on ebay and i cant find websites selling it
As you may or not may know, programming a receiver for "testing" like you have mentioned here is not permitted here. :eek:
The OP CLEARLY stated........
"I done care if i can program the reciver for "testing" i just want to get FTA"
Otherwise TWO mods would NOT have answered his question!
Can an LNB survive being submerged in flood?
Weak signal
