fta system | SatelliteGuys.US
fta system
It probably won't move a C-band dish without additional hardware, though.
Jsmarc02,
The motor or positioners of C-Band dishes usually require 36V for power. Most FTA receivers do not supply this, so you need to add a V-Box or G-Box or something of the like. These "boxes" convert the DiSEqC motor positioning commands to something that the motor on a C-Band or "BUD" dish can use. Basically it is a "go-between" or power converter in a manner of speaking.
RADAR
While the Pansat 2700 won't operate the actuator (move the dish), it will operate a polarotor (the motorized device that is used on most older BUD installations to change the polarity and adjust skew).
Question on Sun Outage Calculator
NASA TV is moving
