I'm SO glad to see this post...this has been happening on one of my HWS's since this AM, but not on the other, though it was tuned to different channels. On the bad one, I only changed around a couple of channels & it was doing this on all of them, so I honestly thought the receiver was dying.We're aware that there are multiple channels with pixilation. We're working on a resolution now.
Is this problem solved now?We're aware that there are multiple channels with pixilation. We're working on a resolution now.
The issue was resolved at 2:02 PM MT yesterday.Is this problem solved now?
Our picture quality is poor and I think sometimes getting worse. Channels freezing a lot of the time and some channels it'd like watching the old Japnese movies where you hear them speak and then about three seconds later their lips move.The issue was resolved at 2:02 PM MT yesterday.
If this is your frequent experience, I would suggest contacting technical support. You may need your satellite repointed or moved.Our picture quality is poor and I think sometimes getting worse. Channels freezing a lot of the time and some channels it'd like watching the old Japnese movies where you hear them speak and then about three seconds later their lips move.
Last night during 911 Lonestar the picture froze and pixellated 42 times(yes 42 times), we have a clear line of sight, weather was clear, signal level on the locals around 50, other channels in the 60's and 70's.If this is your frequent experience, I would suggest contacting technical support. You may need your satellite repointed or moved.
Limited time offer
