FYI - New Fortec Mercury II Firmware Available | SatelliteGuys.US
satcustomer
304
California
Firmware - v.1.51 ( June 15, 2007) Click Here to Download
- Modification to SR manual entry.
Downloading software to your receiver voids the manufacturer warranty.
Perform a Factory Reset (restore defaults) before and after downloading software to your receiver. This ensures that the new software performs correctly.
Note:You can do a Channel Backup from the Factory Reset menu before changing the receiver's software. This will prevent you from losing any channel data.
Download
thanks
I just got one, so thanks for bringing the firmware update to my attention.
It's easy to overlook these things unless someone points 'em out. :up
...or you're havin' a big problem... :eek:
I'm having trouble with version 151 also and would like to go back to Version 145. Problem though, didn't save the old one. Can someone post it? Thanks
Thanks Brent636. I got it and will make sure that I keep a backup, in case of future update problems
Motor Up or Down?
New project...several questions
