The little gray kangaroo on the lower right of the screen is an indicator that a Hopper and a Joey are using the same tuner. It can be a useful warning if, for example, you are watching on the Hopper and someone else is watching the Joey while 2 tuners are being used for recordings. You would know that maybe a polite negotiation would be in order before you changed channels. At any rate it might indicate that you should check the red button tuner use before changing.
Learn something new every day with these boxes.
