G10 No audio on KAMT & KEYU | SatelliteGuys.US
Morbius56
7
Using a Pansat 3500. Picture is perfect ,but still no audio. I have re-scanned it twice and the same thing. I understand its AC-3 and according to Global-cm
"AC-3 Audio requires separate stereo receiver or decoder, to recover audio signal, when connected to an MPEG-2 FTA receiver equipped with suitable unfiltered baseband output jack. Many newer PANSAT units are so equipped"
Is the Audio PID off and can it be changed? Also did anyone catch the wild feed of NFL Networks pregame show for the PROBOWL? Gotta love this FTA stuff.
Mike
those two are AC-3 outputs so you need an external audio receiver that can decode dolby digital for it to work. You WILL NOT get audio on it unless its hooked to the external audio receiver
LNBF help
using gtools to with pansat 2700a
