G18 @ 123w | SatelliteGuys.US
G18 @ 123w
bevdish69
5
I just bought a 33" dish, a Sat Radar LNB SR-125 (Standard Single LNB 10750) and am using a VS Ultra. Trying to find G18, in Brantford ON. Canada. Set dish @ settings found on a dish pointing site in my area. Question is my s goes up and down(59-74) when I move the dish, gets real high(79) when I get to the location the looks right, but the q wont move. Tried moving the dish up down left and right, and playing with skew, but nothing. Am I doing something wrong?
Can I find bird with skew at 0 then ajust?
Settings
LNB: Standard
LNB POWER: ON
LNB FREQ: 10750
S22: off
TP: 11805 (Strong tp i was told)
Diq Port: port 4
ultra
If you have the receiver out by the dish, watch the signal meter as you pan the dish around, it should go up a few points when you get close to an active sat (if it works like my ultra does). Once you get better sig strength you can try a blind scan and see if what it picks up. Crude way of doing it, but it works for me. Or, if you do it the other way, enter the transponder then sit on the setup menu, it'll show you sig & quality both, if you hit the right bird.
I've set up quite a few other dishes at other birds, never had this problem before, but I also have never done any linear before, all circular bird set ups.
Diq Port: port 4
Are you using a DiSEqC Switch? If so, double check where it is connected. For Setup, you may want to connent directly to the LNB. Also, never connect / disconnect to a DiSEqC Switch with the recevier's power On, always turn Off the Power switch on the back ov the receiver.
Set the LNB's skew before try to find Sat.
Universal KU LNBF - Single Fortec Star Wideband
I don't know if the VS works this way, but a couple of the receivers I have make it difficult to search for satellites when connected through a DiseqC switch.
What I found, was that if I had a dish connected say on port 4 of the diseqC switch, that I would put the receiver on a transponder, and start searching for the sat, but what would happen is that after a while, the receiver will start switching switch ports on it's own, apparently looking for the signal. I say apparently, because it might just be caused by a data error, since another feature of all STBs I've used is that if it doesn't lock on a signal, it will send out additional diseqC commands to make sure that the switch is in the right position, and it's possible that a data error puts the switch in the wrong position.
I became aware of the above once when I had 3 different dishes connected to a DiseqC switch, and two were already aimed at the satellite I was trying to aim the 3rd at. I had a TV out at the dish, and also had a meter on the dish I was aiming.
What happened, was that while moving the dish, all of a sudden, the meter went dead, ie loss of lnbf voltage, and at the same time I suddenly got a strong signal indication on the TV. I went to the receiver, and reset the port via the diseqC switch setting, back to the dish I was on, and the meter lit up again, and the TV signal went off. Then, while moving the dish again, the same thing happened, ie signal meter went dead, and the TV came on full signal.
Even though the above behavior is rare, and I've only seen it happen a handfull of times, I've since decided that it is more dependable to bypass a diseqC switch while searching for a satellite. At least if it's going to take a while to find it. My suspicion is that these newer receivers are trying to do things they shouldn't be doing on their own, but as I said, it could be just a situation of data errors.
Thanks B.J.
"all of a sudden, the meter went dead, ie loss of lnbf voltage" I was gonna ask about this, on my VS I think that the S: is the signal (voltage) between STB & LNB, and after trying to find bird for about 15 min. it drops to 0% I then turn the power off/on and it comes back. I'll try it out direct conect and see what I get.
bevdish send me a pm.I maybe able to help you out.I have the same setup except with a motor.I live in south ont and you may not be to far of a drive.
Pointing a Bell, Dish, or DirecTv dish is a lot easier than trying to get G18. You need to move the dish in very small increaments and wait for the signal meter to react. Without the skew set close, the quality will also not rise. Also try moving the LNBF forward and back in the bracket. Don't trust the markings on the dish for elevation, they may be off. Try a few degrees either way. Remember, small, very small movements and wait a few seconds for the meter to react.
G18
The way I find Galaxy 18 is the easiest way I know how...
I use my sat finder program, get the settings as close as possible for Skew, which for me is
something like this,
Elevation: 29.3°, way to low for me
Azimuth (true): 236.5°
Azimuth (mag.): 243.8° using Compass, not even close
LNB Skew: 42.2°, this is close to being correct...
Dish Skew: 90.0°
The Azimuth and Elevation is not even close for me for some reasons...even using a GPS and getting it right down to a degree...
What I do is Find 121 because it is easier and has a stronger transponder for me. Normally 121 is far easier to locate in my area...
Once I find 121, I drop the dish about 2 degrees and pan right very slowly, normally only a couple of degrees till I get a signal on my meter. Once I do that, I Blind Scan, Power Scan or whatever you want to call it... Normally then it's just a manner of peaking for best "Q"
If you can find 119 or 110 then you are close just remember that...
You are only just a few degrees away from 123...Its just a matter to keep in mind, in my area, 119 is higher in elevation so I have to drop a degree or so with each pan...But by far 121 is the easiest to locate here and once that is found you are very close, or here you would be...
By no means am I an expert, I just know what works best for me and me alone...I do know what I've read and every thing I have read about locating Galaxy 18 suggests finding 121 first...
New with a few question
Sun,Moon and Mirrors
