g18 ? | SatelliteGuys.US
g18 ?
anything on g18 worth watching i moved of it a 1 and half years ago was wondering if their is anything on c-band ?:)
The different list doesn't show much, but depending on your receiver type and if you can get AC3 channels I'd rescan it and see what you can get.as there maybe something you like.
Is there something on 123W that I'm msising?
Last I checked there were like 4 KU channels and 2 C-Band channels
Now there's a whole lot out there on that satellite, unfortunately all are scrambled and not free, but I did scan in 3 channel on C-band side with only one having any active programming as the other two have a nice test pattern and audio.. Can't check KU as I'm not setup for that.
FTA install in Dallas
How tall of pole needed above ground
