G4TV on telstar 12 problem | SatelliteGuys.US
firehorsevirgo
7
75 percent quality on g4tv..using pansat 2700a factory bin....04 lnb 3 ft fortec dish...can receive all other channels except g4tv...did blind scan as well as slightly changing..frequency..no dice....had similar problems on hispasat with the cinema plus channel with a 99 percent quality..but after 3 tries of using transponder scan it finally got it...no such luck with g4tv...any suggestions ?....AL
have anybody on here that might have a solution or had a similar experience on another sat..maybe same solution for this problem ?
When I was on Hispasat B,C,D, -could not go farther - w/36" dish - could only
peak best transponders at around 70 % here in Iowa. No 15 deg. this far west...
Is it possible to have it all ?
DIY Picture in Picture.
