Galaxy 18 123w ku alignment issues? | SatelliteGuys.US
bigblock
2
ok
I have a Super Buddy meter and can lock Echo 9 @121 w and G13 @127 w but cannot lock G18 @123 w. I have latest s/w loaded on meter and have used 11805, 4.580 settings along with others with horizontal set on L.N.B. Anyone have any advice?
Looks like you've got a really strong transponder picked out, you should be able to find it. Check out dishpointer.com to check your settings for your location. Have you skewed your LNB? When I was aligning my dish for 125, I forgot to skew my LNB...couldn't get it. Once is skewed to about 45 degrees per dishpointer.com's suggestion, I locked on it. Good luck! Don't give up!
NBC East HD / Universal Sports on AMC3?
Hard packed clay!!
