Stored the satellite positions and renamed the C band satellites into the Gbox. How do I set the microHD to show the channels in the satellite that the Gbox , moved to?.
Thank You
Thank You
Not quite sure if I understand your question right or not, so disregard this if I'm way out in left field here. If the Micro is making the G Box move the dish all right and all you need is the channel list, pushing the OK button should bring up the channel list for whatever sat you're on.The Gbox moves the C band dish to the selected satellite with no problem. The thing is that I cannot get the microHD to show the channels from the selected satellite, I have to go and press the Satellite button on the microHD remote control in order to view the channels from the selected satellite.
How and what is needed to be done in the microHD setup procedure to make the Gbox and the microHD to be in sync.
Thanks again.
Limited time offer
