Genie and an RF Remote | SatelliteGuys.US
JonUrban
578
Eastern Connecticut
If you configure the Genie to use an RF remote, does that deactivate the IR sensor? In other words, if you set up the Genie itself for RF, does that mean you can no longer use an IR remote on the unit?
Correct, it only works one or the other, not both at the same time.
Anyone done AAA + Referral RECENTLY??
March Madness Live App
