Genie recommends | SatelliteGuys.US
Genie recommends
AJF316
24
Florida
Let's say I find a show under Genie recommends. I watch it and like it so I set up a series. If I then remove it from the genie recommends. Does it think I don't like it and won't recommend more shows like that one. Or should I just leave it and not remove it. Also there is shows it recommends that I already have set up on other boxes to record the series. So if I remove them from genie recommends does it think I don't like those as well. I like the feature just want to remove some so it starts looking for new shows for me to watch. Is it actually going off what I currently watch or just randomly recording shows. Thanks.
Genie recommends and your series recordings are totally different. If you setup a series to record after you watch it from the recommend and then delete the Genie recommendation your series recording will not Change. If you remove it though it might not pickup up something else that is similar.
John
Questions about Genie
