GEOSAT Pro DSR200C - Channel Search Setup - TP Frequency Change not saving | SatelliteGuys.US
SAARNO
3
New England
Hello all,
I am setting up my new DSR200C receiver (replaced my dead DSR100). When I select a different TP FRequency for Galaxy 19, I do a channel search and see the channels I want. When I save and exit (bypressing 'exit') and go back in to verify the change, it goes back to the default TP.
Has anyone had this problem?
- Scott
Make sure when it load the channels after scanning you hit OK to save then when you exit out it "do you wish to save changes" or something like that. Make sure to say OK and not exit. That was something I had to get use to also ;)
Its a great receiver. I have one and its used heavily on blind scanning :)
I used to make the same mistake with my Coolsat 8000 when I first got it.
SatHawk S9 PVR800 Firmware Problem
Motor limit change??
