GeoSat110C compatable | SatelliteGuys.US
alemmoe
58
pottstown,pa
I pulled one of my three GeoSat recievers:), the GeoSat DSR 110C from my glorystar system only to find the signal for another FTA satellite system using its blind scan feature,because the blind scan does not work on the sonicview.
I have not been able to get any type of signals with the GeoSat 110C. Is the GeoSat 110C compatable with the Invacom QPH-031 LNB and my 39" Hot Dish 90 .
If you dont know,do you know who would? :confused: Thanks [ AL] alemmoe
Yes, The GEOSATpro DSR100c can be used as a standard Free to Air receiver. It is completely compatible with the Invacom QPH-031 LNBF or any other LNB(f) and satellite dish.
Select the satellite, set up the LNB type and any switch settings then scan.
Channel losses...
Bethel TV and Radio Moving to Galaxy 19
