GEOSATpro 100c issue... | SatelliteGuys.US
hillsmi
160
3
Michigan
This box won't pick up ANYTHING...tried factory reset, tried Glorystar mode, tried All Satellites mode.
I know the dish aligment and cabling is good, because it is used for another FTA box, but when I tried connecting this older box for a friend to see if it works, I can't seem to get it to pull in anything?
Unless I'm doing something completely wrong in trying to blind scan? I've tried different corresponding freq and SR, but whenever I scan, NOTHING shows up. Could it be a dead box, or am I missing something?
Help and suggestions appreciated. Thanks
Well, according to my volt meter, the output from the LNB port is only measuring about 5.9 - 7.7 volts, whereas my good box, the output is just under 18 volts.
So, does this indicate a bad unit? Trash, scrap, or is there something that can be done to remedy?
AMIKO Amiko A3 Guides and Instructions
Which receiver?
