This my be a silly question to some but how do I install the motor tube of the hh90 in the new pole bracket on the geosat pro 90cm after removing the bolt that go through the pole clamp and elevation bracket ?
I guess following the directions first leads to less silly questions thanks everything lines up and now I need to mount the dish and motor tube to the motor aim and re enjoy ku fta until I get the bud working againFirst place the 90cm clamp onto the HH90 tube, then assemble the dish butterfly bracket onto the clamp.
No switches same lnb USALS is set correctly in the mini hd se only thing I can think of is the dc pulse is experiencing interference from a AC source the cable going overUsing USALS or DiSEqC 1.2? Each active satellite have USALS motor mode enabled? Input your location Longitude and Latitude in the USALS menu?
Different LNB, switch or power settings on the mini HD SE vs the PCI card?
Limited time offer
