GEOSATpro DVR1100c / DSR100c Firmware Updates Available | SatelliteGuys.US
SatelliteAV
6,486
186
Roseville, CA
The GEOSATpro DVR1100c and the DSR100c receivers are the only hobbyist FTA receivers in North America to provide automatic or manual firmware updating via satellite. No need to download or transfer firmware files via your computer. Simply aim a dish at Galaxy 19 and update your receiver to the latest factory firmware!
New firmware is now available for the DVR1100c and the DSR100c models. You may download the firmware updates via satellite Galaxy 19 @ 97W Ku-band or download the files and install with the DVR's USB port or on either unit via the RS-232 port.
7/20/2009 Update
Automatic or Manual Firmware Download versions:
DVR1100c: GS_3.20
DSR100c: GS_1.18
  • After Firmware Update, Reboot or Master Power Restart receiver will go to Channel 1 for resetting the automatic GMT time reference (if activated)
  • Removed Blind Scan function from TP Edit Menu
  • Corrected Lock-up issues for select HD / PowerVu channels and TP Edit Menu
Attached Zip Contains:
GS_3.20_D1.20.GPB - DVR1100c Firmware File / use with loader
GS_3.20_D1.20.LDR -
DVR1100c Firmware File / use with USB
GS_1.18_D1.20.LDR - DSR100c Firmware File / use with loader
http://www.satelliteguys.us/attachment.php?attachmentid=39884&d=1248144790
No more Fox channels?
Doubled my signal :-)
