GEOSATpro DVR1100c: Is there a way to save channels to my computer ? | SatelliteGuys.US
Lassar
SatelliteGuys Guru
149
Illinois
I lost power for a few seconds.
Seen to lost channels on all but one satellite.
_
what receiver are you using?
Some will work with a program called Channelmaster where you can save the channel list to the computer. Some receivers have a USB option where you can save to a USB stick (GeosatPro is one)
_
Power outages will not cause loss of transponder or channel data.
If you wish to save a custom channel list to external USB memory, press Menu >>> Utility >>> USB >>> Green Button.
I've saved my channels from my Geosat 1100c to a usb stick, but could not bring the file into Channel Master for editing etc. Will CM work?
36" Dish Needed in Pleasanton, CA
Help in buying new dish
