geosatpro gs120 motor install? | SatelliteGuys.US
amc1
im looking for install instructions ?i lost mine .i was having trouble last fall setting mine up so i gave up on it .now the weather is worming up on the rock
here(corner brook nfld canada)want to give it another try . also if the west and east slider limitswere set at 80 degrees would that gave me trouble ?
if i was on 101 west and want to go to 87 or 97 west the dish would move all the ways to the end of it limits to far?:confused:
Download a copy from the FTA Manual Area
http://www.satelliteguys.us/fta-manuals/92611-geosatpro-gs120-motor.html#post847612
You will not have any issues covering the slots between those two points. They are very close together and should move in a les than 5 seconds. The Hardware limits are adjustable to any point if you need a hardware limit. Many owners have removed the stops to allow even greater movement.
WorldTV installation- need help
SetEdit (please read)
