Get Rid of Dish Icon on TVG on a 322? | SatelliteGuys.US
If you're talking about the little "interactive" icon in the top right corner on channel 405, try this.
Menu 6-1-6 "TV Enhancements"
It's there to tell you that there is an interactive gambling application that will download if you press the "Select" button on the remote. Turning off TV Enhancements will make it go away.
on the 322 it is
Menu 6-1-9 and that worked thanks from the 6-1 i was able to figure it out
Local Channels On Dish Network
vip211 signal loss message 015
