My SD was working flawlessly till this evening when it stopped showing any of the 110 & 119 channels. When I checked the signal strength for these two birds, it shows a red bar (Wrong Sat, signal strength at 67-68). No major weather change in the West Coast (Bay Area) . I also visually checked the SD and did not see any twisting or lateral movement (the install guys mounted the SD on a wooden fence post and anchored it with two side straps mounted to the top of the wooden fence). Called DNW and they told me to wait till tomorrow before calling for their tech guy and will charge me $50 for the technician to come home and fix it. I am hoping to do the fix myself and see if I can save the $50.
Is this a major fix or can it be fixed by simply adjusting the SD? Given the 119 is right behind the 121 why am I not getting a good signal on the 119?.Can cloudy weather be the cause?
When the SD was initially installed (in August) I had a signal strenght of 100 on both the 119 & 110 W birds.
Appreciate any help!
