It's been a pretty good week here! Weather is warming up, I'm between busy work periods, so I've checked out a few things with the Birdview I picked up from Radzoid and am inching closer to getting it in the ground.
I've checked out the motor and the dish mount moves great, I just modified the scaler ring to fit a corotor II+ feedhorn throat (and got the Chappy scaler ring bolted to the birdview scaler ring so all I have to do is loosen/tighten the set screw on the chappy to set the throat distance where I need it). I"m starting out 1/8" extended from the birdview scaler ring because I'm making the assumption the focal length of the birdview goes to the dish-facing surface of the birdview scaler ring, whereas the Corotor II+ focal length goes to 1/8" inside the chappy throat. I can adjust it as needed when I get it on arc and can see how the signal levels are.
Friday, I fixed the only broken feedhorn support and I believe I may be the only one to have done it this way because I don't recall any postings about fixing broken supports this way.
I was able to keep the aluminum support leg. What I did was "screw extracted" the broken-off threaded part of the support from the support holder welded to the dish. I turned the support 180 deg around (so the remaining good threaded end screws into the restored socket) and I filed flat the end with the broken threaded part and drilled a hole into the end of the support rod and tapped it for a number 10 screw to mount it to the scaler ring. I didn't have to use a long 5/16" steel threaded rod to fix it.
I have to start digging the hole, now that I decided I need to hot-switch the birdview with the Orbitron 7.5' dish that the birdview is replacing. The original plan was to adapt a piece of the 6" birdview pole onto the orbitron pole, but I may need the orbitron before I can get around to getting the birdview on arc.
with work about to pick up again for the next month, I only have a day or two to try to get the hole dug and cemented plumb, otherwise it will be slower as I can only spend a few minutes here and there working on the hole before darkness sets in each evening.
I'm pretty stoked with the mods/restoration I was able to get done this week.
I do have a question about the motor part - is there a mechanical stop or will the dish run off the gears and go crashing if I go too far east or west? I plan to drive the dish by spectrum analzyer (watching my analyzer to see where I am as I drive the dish with my 24V power supply). I may eventually get around to buying yet another vbox and doing the reed sensor mod.
