Getting Rid of Timer Bar in Pause | SatelliteGuys.US
Theres a code to make it disappear quickly. Its one of the few codes I use on mine but it only works on TIVO model of DirecTV DVR.
While a recording is playing, press the following buttons in this order. Don't pause too long or it won't work. The bar will then appear for only about 1 or 2 seconds when you pause then disappear.
After you press the buttons in correct sequence you will hear 3 bongs.
Select - Play - Select - Pause - Select
If it doesn't work the first time, press clear and start over. Sometimes the buttons get out of sequence or something.
NASA, HDNet ANNOUNCE HDTV SPACE SHUTTLE BROADCAST PARTNERSHIP
Spaceway 2 at 99 Degrees Update?
