Glorystar Firmware Update Thread - DSR100/DSR200/DVR1100 | SatelliteGuys.US
Not open for further replies.
Glorystar1
788
Roseville, California
New Firmware Updates will be posted to this thread by Glorystar.
Please do not use this thread to discuss firmware or channel changes.
10.03.2008 5pm PST
GEOSATpro DVR1100c and DSR100c receivers Auto Update feature is defaulted to the ON mode. Channel updates occur automatically each Tuesday morning at 3am in the local time zone. If an updated Firmware is available, a screen will prompt the customer to select YES to accept or NO to ignore the Firmware update. Firmware updates must be accepted by the customer and usually will not be automatically pushed to a receiver. Firmware updates will erase any timers, custom channel scans and favorite channel lists. The DVR1100c will postpone the Channel or Firmware update if programming is being recorded until the event timer expires. Channel Updates do not erase timers.
If a GEOSATpro DVR1100c or DSR100c owner disables the OTA Auto Update mode, the receiver will not be updated with any new channels or Glorystar information / promotional channels. The receiver must updated manually to add new channels and updated features. DVR1100c owners can save a custom channel list to a connected USB drive then reload after updating the firmware. DSR100c owners can save custom channel list via the RS232 port with the channel editor then reload after updating the firmware.
Automatic or Manual Firmware Download versions:
DVR1100c: GS_3.13
DSR100c: GS_1.12
  • Update satellite and TP lists
  • Provides 5 Glorystar information and promotional channels
  • Add "Removed Channel Information" screen for deleted channels
  • Implement new OTA automatic updating data protocol
  • Correct automatic auto clock setting issue. Updates time each time a channel on TP G25/G19 12115 is viewed or during the weekly OTA update
  • Correct manual / automatic auto clock manual setting issue which required a factory reset to return to the automatic time setting mode
  • Multiple channel scans create sequential channel numbering correcting the duplicate channel numbers issue
Channel List Update
D1.07
11/4/2008 Update
DVR1100c: GS_3.15
DSR100c: GS_1.14
  • Update TP lists
  • Maximum Manual Record time removed. Maximum record time is now only limited only by size of connected available storage.
  • Correct Picture In Graphic (PIG) image freeze issue while in the EPG.
  • Added a pop-up window warning that Firmware and Channel updates will not occur if the OTA Automatic Update is turned off.
  • When in scanning new channels, new channel numbers are added to existing scanned in sequential channel numbers instead of starting again from channel number 2000 TV or 4000 Radio.
  • Motor Control adds an independent on and off control of USALS function for each satellite.
  • Glorystar promotion channels 1 to ch. 5 properly displays stored video and audio files if Time Machine is activated.
  • Eliminate random channel display after rewind or fast forward of recorded Time Machine programming.
  • Correct Channel Banner information of the current channel is displayed while Time Machine is activated.
  • Corrected Blind Scan of Galaxy25/Galaxy19 KU hanging on TP 11867 and not completing the scan.
Channel List Update
D1.08
1/1/2009 Update
Channel List Update available via OTA
D1.09
No new channels. Remaps several channels to new transponders.
DVR1100c Update via USB port use file: GS_3.15_D1.09.GPB
1/23/2009 Update
D1.12
* Allows Firmware / Channel List updating in Advanced mode in addition to the existing Glorystar mode. (receiver may be automatically or manually updated if a dish is aimed at Galaxy 19 with either no switch / 22KHZ ON and/or DiSEqC position #2.
* Updated Satellite List. Added 15 New empty satellite positions to the Advanced mode and 10 positions to the Glorystar mode.
* Added Favorite lists for:
1. Adventist Channels
2. Spanish Glorystar Channels
3. Russian Glorystar Channels
4. Arabic Glorystar Channels
Selected Favorites List remains in effect through a Data upgrade, but is reset to the All Channel mode during Firmware update.
1/31/2009 Update
DVR1100c: GS_3.17
DSR100c: GS_1.15
  • [FONT=&quot]Add: New channel entry by direct transponder and PID information[/FONT]
  • [FONT=&quot]Add: Select and store default audio settings independently for each channel[/FONT]
  • [FONT=&quot]Add: JPEG viewing function
    [/FONT]
  • [FONT=&quot]Restored live channel display in the Channel Manager preview window[/FONT]
Channel List Update
D1.13
No new channels. Update with new satellites and active transponders
7/20/2009 Update
DVR1100c: GS_3.20
DSR100c: GS_1.18
  • After Firmware Update, Reboot or Master Power Restart receiver will go to Channel 1 for resetting the automatic GMT time reference (if activated)
  • Removed Blind Scan function from TP Edit Menu
  • Corrected Lock-up issues for select HD / PowerVu channels and TP Edit Menu
Channel List Update
D1.20
Attached Zip Contains:
GS_3.20_D1.20.GPB - DVR1100c Firmware File / use with loader
GS_3.20_D1.20.LDR -
DVR1100c Firmware File / use with USB
GS_1.18_D1.20.LDR - DSR100c Firmware File / use with loader
12/08/2009 Update
DVR1100c: GS_3.26
DSR100c / DSR200c: GS_1.22
  • Added DiSEqC 1.1 support for multiple switch and cascading DiSEqC control
  • Added Blind Scan frequency upper and lower range option
  • Modified tuner handling routine providing sensitivity and threshold gains
  • Modified decoding routines to minimize video display errors for non-compliant dvb MPEG-2 transmissions.
  • Implemented new audio decoding routine to provide quicker audio pid lock
  • Added USB Channel Updating and Channel List file support for new DSR200c model. (Channel Master editing software support using CNX import/export file type on DVR1100c and DSR200c models)
  • Increased Multi-CAS compatibility options
  • Corrected channel name mapping error from several G19 Globecast muxes
  • Corrected Lock-up issue occurring during GMT time updatingat time of install
  • Added AMC4 "Adventist" single satellite reception type set-up to installation screen with automatic time setting from 11822 transponder.
Channel List Update
D1.26
Attached Zips Contain:
  • Firmware Loading and Firmware Support Documents
  • RS-232 Loader Software Program
  • DVR1100c Firmware Files (RS-232 loader and USB)
  • DSR100c/200c Firmware File (RS-232 loader)
  • DSR200c Firmware File (USB)
12/18/2009 Update
DVR1100c: GS_3.27
DSR100c / DSR200c: GS_1.23
  • Corrected MPEG Start-up Images
Channel List Update
D1.26
11/30/2010 Update
Automatic or Manual Firmware Download version: DVR1100c: GS_3.33
Available for download via the satellite Galaxy19 KU OTA-SSU update on transponder frequency 12115, PID 330.
  • Fix: Random C-band TP Lock-up.
  • Fix: Increase scanning speed. Channels with no service name will not have a 45 second search delay.
  • Fix: Scan - previously would skip certain channels such as G18 - KU / Daystar.
  • Add: Providing Naming for TV and Radio services which are not properly referenced in the PMT.
  • Add: Blind Scan Scan Options: FTA / ALL - Assists in scanning only the Free channels or All channels.
  • Default: Blind Scan Ending IF Frequency: 1450 - Changed to match the most common LNBF LO of the Standard Type LNBF.
  • Default: Search Option changed from SAT (FTA) to 1TP (FTA) in Search Screen.
  • Default: OTA-SSU satellite, transponder and pids reassignment (press Red button in OTA screen) - This will allow the receiver to be updated from additional satellites and transponders if ever needed.
  • Update: Satellite List Channel List Update D1.48
  • Firmware V3.33 Loading and Firmware Support Documents
  • DVR1100c Firmware Files (RS-232 Loader and USB)
12/01/2010 Update
Automatic or Manual Firmware Download version: DSR100c / 200c: GS_1.34
Available for download via the satellite Galaxy19 KU OTA-SSU update on transponder frequency 12115 and 11842, PID 330.
  • Fix: Increase scanning speed. Channels with no service name will not have a 45 second search delay (now approx. 15sec.)
  • Update: Satellite List Channel List Update D1.49
  • DSR100c / 200c Firmware Files (RS-232 Loader and USB)
2/01/2013 Update
Automatic or Manual Firmware Download version: GEOSATpro DSR100 / 200: GS_1.37
Automatic or Manual Firmware Download version:GEOSATpro DVR1100: GS_3.34
Available for download via the satellite Galaxy19 KU OTA-SSU update on transponder frequency 11842, PID 330.
  • Update: Satellite List Channel List Update D1.76
Attached Zip Files Contain:
  • DVR1100 Firmware V3.34 USB Loading and Firmware Support Documents
  • DSR100 / 200 Firmware V1.37 USB Loading and Firmware Support Documents
  • RS-232 Loader Software Program and Support Documents
Glorystar Welcomes WBN Revival Channel on Channel 129
Updating a DSR100c firmware - how to use the rs232 port?
