GloryStar-Question | SatelliteGuys.US
GloryStar-Question
Glorystar is basically just the religious channels on 97W
Any receiver can pick them up. If you get one of their receivers (GeosatPro) they have the option to do the Glorystar option which loads the channels automatically and updates as need be. It truly is plug and play. You can always swap it in the menus to hobbyist (advanced) and use it like a regular receiver
Openbox S9 or S10
PBS on the chopping block!
