Glorystar/visionsat setup | SatelliteGuys.US
homebrew82
4
NW USA
I picked up a Glorystart dish and viviosat IV 200 PVR to see if I could get started. I was able to position the dish and pick up 97W on the #1 LNB. Swithing to the #2 LNB, 101W came through immediately. I'm struggling trying to connect both LNBs through a DiSEqC switch and see channels on both satellites. The only satellite that I see is the one coming through the #1 port on the switch. I tried another 4-way DiSEqC switch to no avail. I find the manuals to be less than enlightening. Am I missing something in the PVR setup? Thank you for your time.
In the Installation Menu on the Visionsat are you assigning one satellite to DiSEqC port #1 and the second LNBF to DiSEqC port #2?
inexpensive vice grip pliers
white springs tv
